My MF-104m dose not always catch on to the first midi event sent from my sequencer (starting) most of the time it does though sometimes I have to start it a few (three four times) to get it to start syncing (LFO rate LED turning amber) to Ableton.
My MF-108m is fine.
Its not to much of an issue, I thought I would post this in case the Moog techs are reading this forum to find possible bugs.
It could well be I have both my MF’s sending on channel one?
I Have the same problem. I’m using my Roland Fantom G sequencer to send midi CC’s to the mf 104m, and often it seem to go wrong (wrong delay time, or feedback, or lfo settings). I have to play the track 2 or 3 times before it catches the appropriate settings…deceiving…
What exactly is the setup you have when you are experiencing this issue? (MIDI interface, MIDI Ins/Outs, Clock Source, Sequencer, DAW, number of MIDI pieces in the chain, etc.)
Would like to re-create this to see if it is an issue that should be looked into further.
