I’ve recently noticed something strange with my MF-104m : when I midi-sync it directly with my DAW (cubase 4) through my Emu Xmidi 1x1 cable, I can ear a background “buzz” in the MF audio out as soon as I press play on my software and the fooger gets the midi messages, even if nothing is played in the audio in. It’s like you can ear the electric midi signal leaking in the audio out.
However the problem disappears if I sync the MF with my software but with a drum machine between the Emu cable and the MF (using the drum machine’s midi thru).
Did some of you guys ever face the same kind of midi-audio interference problem ?
Now I use USB to an axiom keyboard controller and use the thru to a splitter that feeds multiple devices. No noise this way. Something about having a powered device between the moots and the computer seems to fix the problem. It could be that the powered device is eliminating noise in the computers USB circuits?
Moog stuff typically amplifies noise present in a signal path. Not a bad thing tho, just a thing, lots of high end devices do it.
