MF-104m Delay Problem
hello
I have a big problem with my MF-104m Delay when I connect it to my Minimoog Voyager XL is only a scraping noise. I have the MF-104m Delay newly exchanged, it is still not working. I think it is because of my Minimoog Voyager XL, something’s wrong. I have connected the it as it says in the description but it will not. What am I doing wrong, I hope you can help me who
first, describe to us how everything is interconnected please.
Exactly, a big mistake is to put the delay into the insert in/out. It just won’t work…
Stephen
Here is a picture of my Voyager XL and my MF-104m.
http://1.bp.blogspot.com/-DaJyTR3kp2o/VLLsLSYsopI/AAAAAAAAAXU/-YOiZSH0UTU/s1600/20150111_222741%2B.jpg
That doesn’t look right. It looks like you have your delay hooked into the MULT. Maybe if your output went somewhere else, but this just like like you have input and output hooked to the same line.
You’d need either an insert cable to hook your delay to the mixer out/filter in connection (which will cut off the delay sound with your amplitude envelope) or you need to go from the left/mono output, through the delay, then to your amplifier.
strange why then work my two other Moogerfooger FreqBox and cluster Flux, I just connect and it works, just my MF-104m does not want maybe because it is a delay? :confused:
http://4.bp.blogspot.com/-hLBtrVyAiNI/VLRHVMrWDVI/AAAAAAAAAXk/o-oEHeZnkYQ/s1600/20150111_225329%2B.jpg
I don’t mean to be insulting, but you are doing it wrong.
What example did you follow?
These pictures paint some clues why.
  1. in the delay picture, you show a TRS cable from the insert to the Multi (green). Then you show two instrument cables from the Multi to the delay. You are basically doing the same thing as plugging the output of the delay back into the input. But, you also are only sending this signal to the tip in the Multi. You need a signal on the ring to return and complete the loop.
  2. the “working” picture is different. It appears that you are using TRS cables from the foogers back to the Multi, and a single instrument cable to bridge the two multis. I’m not exactly sure why you would be getting sound, but it’s likely that you got lucky by using an instrument cable to bridge the multis.
To reiterate what Gladmarr said; Try to set up the delay like you have the ClusterFlux and remove the freq box. Use the same exact cables and routing that you show. It might work, but I’m not sure that’s the best way to set it up. I suggest you use a true “insert” cable. A stereo TRS to mono TS Y cable. Plug one side into the input, and the other into the output. You could also do this with the freqbox and ClusterFlux rig, with a single cable from the out of one into the in of the other.
Hope that helps.
*** edit, upon closer inspection, it looks like all of your cables are TS (second photo on the table). So what you are essentially doing is sending all of the inputs and outputs to the same place. It would make an interesting sound certainly, and you might be lucky that it worked for you and I can only assume it was intentional since you have probably read the manual? Let us know if you figure more out!
