MF-103 Expression Pedal Sweep
I am using a Moogerfooger MF-103 12-stage phaser with a Moog Voyager (endless fun..)
I have set the Rate to Zero so that I can control the phase sweep point manually with the Sweep knob - this works fine
However when I use an expression pedal to control the sweep it seems to only control a very small band - i.e. with the expression pedal all the way down it sets the sweep to zero, but with eh expression all the way up it does not open up to full - it only sees to control about a quarter / a third of the full sweepable phase.
Is there a way around this, am I doing something wrong?
Sounds like you have it set up, however most expression pedals have a trim pot on the side that will allow you to set the range of the pedal. Check that it is set to fully open. Set the expression pedal toe down possition and adjust the trim till it reaches where you want it.
That worked - thank you so much!
