Yesterday I purchased a Sub 37. OMG ist a MOOG, I am so proud… Cool machine, vast range of great sounds.
Trying to use it in Cubase 8.0 via USB puts me down. Biiiiiiiig surprise: My oh so beloved Cubase 8.0 stumbles and stumbles when playing or recording. Ist almost líke it is freezing for moments and then continuing to run. Doesn´t even sound like I could create a new sick music genre with it… People would have to make strangest movements matching with eternal chaos clock to dance to this. I assume this might lead to injuries
I have sync set to “internal” in Cubase, and distribute midiclock only to Sub 37via USB. I have “all midi Inputs” set for the Sub 37 track as I want to play and fiddle around on Sub37’s splendid hardware (“all” includes the Phatty itself) and route midi to Sub 37. On phatty midi is set to 7 bit, I turned mdidi clock send in Sub 37 off. Neither CV, Midi or USB are set to duplicate anything. I assume that there is a Midi feedback in this Installation which may be the issue but have no idea how to resolve this. I also wonder if I can learn more from you, what the real issues are.
Thus I ask you, dear community, if something like this was experienced before and how this can be solved. I searched the Forum but only found timing issues where the DAW worked but none where 37 was strong and nasty enough to bring the DAW down. Thus I hope you can help as without Midi Integration its pointless to me…
I don’t know if it’s related, but I had an issue where I could not get the Sub 37 to sync properly to the clock in Logic Pro.
I only had the problem when my sequences had swing. If swing was at the default setting (50% I think), the sync worked perfectly, but with a swung sequence I could never get it to work properly.
Sub 37 should not make Cubase stumble at all… especially if Cubase is the master clock and Sub 37 isn’t sending any clock back to Cubase… make sure ECHO DIN / ECHO USB settings are both OFF on the Sub 37 MIDI settings… although it sounds like you did this already. Does it make any difference if sub 37 arp/sequencer is on, or off?
what version of Windows are you using? There’s a Moog USB driver that might help.
Thansalotandevenmore for your answers. Have been working extensively in my real life work - thus pls. apologize delayed answer.
As I am from Germany I do not use Swing just straight 4/4 No, sincerely I love Swing but for the test setup no-swing setting was used. Thus I assume this can not be the source of error.
Amos, you are right I disabled any duplication. The strange things (driving Cubase even to not respond to anything) happen disregardless of any arp/seq settings but tend to get worse in arp/seq. BTW I use Win 10 which I now find to be pretty unproblematic with my Setup (8 hardware synths, via USB and edirol Interfaces)
I now wired the Sub 37 via Midi and everything works fine, thus I assume the problem lies with the USB Interface. Unfortunately now my Korg Z1 only receives Midi but does not send any - which I hate since I just got myself a good Editor and promised myself to tame that beast (new years eve .
