i am having this issue: If i set Round Robin Mode to ON it works with keyboard, arpeggiator but not with sequencer. Is this normal?
Another issue i have (i think it is a consequence of the previous) is that if i set the Sequence Keyboard Control to OFF - to be able to play the keyboard along with the sequencer - i cannot hold down a key on the keyboard because the next note of the sequencer always steals it.
I wrote up and submitted a ticket. Also not sure if it will help but I figure the more people that write a ticket for the velocity curve may help get it fixed. Thanks.
I wrote a ticket about the sequencer stealing notes a couple of weeks ago. It even exhibits a type of that behavior when you have the sequencer only outputting midi (steals from the keyboard played notes) which leads me to believe it is a software issue. I was going to have the sequencer control an off board piece of gear and solo with all of the voices available on the Matriarch, but it kept cutting my notes off even though the sequencer should have only been affecting midi as per the global setting.
I was talking to a support person at Moog and this is what he said:
“It sounds like you’re hearing the usual function from the sequencer keyboard control off setting. It can be tempting to expect that it would sound like two separate tracks/parts, however there’s no separate envelope for the key presses to travel through. The manual could state it better but it’s currently quite literal in that you can “play along with the sequencer”. In other words, as the gate opens and closes through the sequence, key presses will only be clearly heard when they line up with the sequence. Also, if the key presses weren’t traveling through the filter and amp envelope, they would not be heard at the output.”
Seems like it is working as designed, but not like it’s described.
Nick Batt did a patch in the Sonic Review of the Matriarch that seems to do what we are all trying to do. As far as I can tell he didn’t use the Sequencer/Keyboard control to do it. Maybe someone can get him to publish that patch!!
