I’m trying to get a step closer to polyphony by using a hermod, quad envelope and quad VCA to allow independent envelopes per note. I thought I could send midi to hermod and have it break the notes out into four cv/gates. I sent the CV back to the PITCH IN of each oscillator. I sent each WAVE OUT to a VCA being modulated by an AD envelope. I then routed each back into their appropriate mixer input on the Matriarch and put the VCAs in DRONE MODE and I turned off LOCAL KEYBOARD in global settings.
The pitch is tracking in an erratic way and the notes are still getting gated somehow by the Matriarch. I’m assuming the gating is something I can’t bypass and it happens on each oscillator before the mixer. I also read somewhere that the PITCH IN is meant for modulation and not V/O tracking because it sums with internal cv. Hopefully I’m missing something.
Regarding the oscillators, you are right, they are gated before the mixer, so unless you play 4 keys, the sound wont come from all mixer channels, but as you have found, you can still get the oscillator out from all the osc output jacks.
Have you considered not going into osc pitch in? Set the matriarch to four voice and let it set the osc pitch, then you just need four VCAs patched between each of the osc wave outs and the mixer channels. Then 4 envelopes need to fire in correct order, I think that’s the tricky part - One way is to switch to full round robin mode and use a sequential switch eurorack module. I can elaborate on that if you like.
Or you can just get a midi to cv module that supports 4 note polyphony like the mutable yarns.
HI, i just purchased a Matriarch, and i would like to play it with 6 or 8 voices.
I was thinking to link it to another unit, like DSI Polyevolver can do,
or to some modules.
I 'm courious to know your vision on this argument, how to get the other voices.
If you’re looking for a way to trigger the envelopes in the correct order for polyphony, using a sequential switch module or a similar module that can handle the sequencing of the envelopes can be a good solution. It would allow you to cycle through the envelopes in a specific order, ensuring that they fire correctly for each note.
Alternatively, using a dedicated MIDI to CV module like Mutable Instruments Yarns that supports 4-note polyphony can simplify the setup and provide you with the desired polyphonic functionality.
Have you given the idea of skipping osc pitch in any thought? You just need to patch four VCAs between each of the osc wave outs and the mixer channels after setting the matriarch to four voice and letting it control the osc pitch. Then, four envelopes must fire in the proper sequence; I believe this to be the trickiest part. One solution is to switch to full round robin mode and utilize a sequential switch eurorack module. If you would like, I can go into further detail.
Make sure you disconnect the keyboard from the oscillators in the settings, or the pitch in CV is summed with the keyboard. That’s probably the reason you are not tracking properly.
I recommend looking up “Robe music” on YouTube, he has a number of Matriarch sound design videos where he shows how this can be done.
