Hello everybody! Maybe someone faced such a problem - when you press the note C, the matriarch plays A# and so on. Each note you press on the keyboard is actually two semitones lower (all default oscillator settings). Thank you
I haven’t seen this problem. Have you checked to see if you have accidently bumped the master tune knob in the back of the unit?
John
Did you resolve your issue? I’m having the same problem with mine.
Hi, my Matriarch has also started behaving like this after the 1.3 update. Any luck on a resolution?
One really weird behavior is if I wiggle the fine tune knob it wil correct it self back to C for a second before jumping back down to A#
