My Matriarch does not seem to send or respond to midi sustain. When I look at the midi stream in Midi-ox - the Matriarch seem to just delay the sending of note off information rather then sending a midi sustain control message. It does not respond to midi sustain from another controller.
Could someone verify this for me? If it is an issue I will raise it with Moog.
John
Confirmed - but I’m not sure if it was intended to respond as sustain is not listed in the midi doc. Matriarch also doesn’t respond to velocity although this is listed as both transmit and receive. But maybe it just means it goes out the thru port (haven’t checked).
I received a response from Moog support stating that they are working to add this feature in a firmware update.
Any more word on this update? I have been dying to get that cc64 going!
