Hello, I have been trying to make my ring mod act as a volume pedal, I’m close by plugging my EP-3 into the mix CV input, then putting a dummy plug (1/4 to RCA adapter not connected to anything) into the carrier in, when I sweep from heel to tow the volume gets quieter, as I fade from the dry signal to the wet which is the muted carrier, works great but I really want the full volume when the tow is down and silent when its in the heel position. I thought by switching the mode button from (standard to other) on the EP-3 pedal would do the trick, but didn’t change anything.
does flipping to other switch the Tip and ring? I think what I need to reverse the direction of the pedal is to reverse the tip and sleeve? Or is there an easier configuration that I just haven’t thought of? Trying to do this without adding much external gear.
Any thoughts?
