Mac Audio Midi Setup for Sub 37
Hi
I am using Logic and used to be able to select the Sub 37 as the output when creating a new external midi instrument.
I did something in the mac’s audio midi setup utility and I can no longer see the sub 37 listed in the output drop down menu.
I noticed that my other devices have port arrows on them and the 37 does not.
The add port button in the sub 37 properties is greyed out so I cannot add a port to it.
Can someone help please?
Do you see the Sub37 in the audio midi configuration?
And do you see a port there?
One option is to throw away the Moog Sub 37 in the audio/Midi configuration in OSX and scan the Midi-bus.
The Sub 37 should appear as a midi device now.
After this the Moog should also be selectable in Logic.
Yes i do se the Sub37. I did what you said and the sub37 is picked up
but it still has no port numbers on it like the other devices.
Also I still can’t select it in logic
I am also getting some kind of midi feedback loop.
What are your settings in the Sub37 midi menu?
IN PORTS:
OUT PORTS:
ECHO DIN IN:
ECHO USB IN:
IN CHANNEL:
OUT CHANNEL:
SEND PGM CHANGE:
RCV PGM CHANGE:
I’ve got it working now thanks.
I switched my native instruments maschine and Komplete kontrol on and off and it worked.
