M32 does not Synch to Midi Clock
How do I configure my 2 M32’s to synch to midi clock?
The M32’s Tempo LEDs flash red at their respective tempo settings and they ignore midi clock.
Both M32’s play well with my Roli Block and Roland PK-6 over midi.
I have a Disaster Area Designs SMARTClock in my midi chain.
All other midi gear have automatically synched with the clock.
Thx!
Check out if the Tempo Input is set to DIN Sync mode. you can change the setting following the instructions on page 50 of the manual
Thanks bichuelo. I read about the tempo input setting on page 46, and thought it only applied to the tempo input jack in the patchbay. I’ve now set both M32s tempo to din sync mode but neither of them respond to the midi clock.
