M104 and M105 tempo sync?
I currently own an M104 delay (as well as a Minifooger tremolo) and am seriously considering purchasing the 105 Murf. I am a guitarist and currently do not run midi from the stage. Is there a way to sync up these pedals by using the tap tempo function on the 104?
Thank you
Hi, welcome to the forum.
The answer is no. You can sync them using a MIDI source though and that could be any number of things.
There are possible solutions from disaster area, and you will likely need a splitter like a MIDi solutions Quadra thru.
