LPF issue!!!
My LPF developed an odd issue tonight - never had it before.
The LPF is connected to my MP-201, controlling the mix, res and cutoff. All working great, however, when you disengage the effect, it is still audible, for example you can still hear an LFO going quietly, or if you rock the gas pedal on the cutoff, it still noticeably effects the tone - not to the same level as when it engaged but definitely there. Makes using LFO’s a nightmare.
The only way to remedy this is to unplug one of the 3 connections to the MP-201, then it returns to normal!? Am I feeding it too much CV with the 3 connections? This only started today so I’m
Baffled!
Shep
