LP voltage-scaling problem
Does anyone here know if the LP scales it’s pitch at exactly 1 volt per octave, or is it perhaps something slightly less, like the micromoog was?
I’m having some difficulty getting it in tune when i use it with my analog sequencer. I’ve tried my best to calibrate the voltage output trimmer in the sequencer as close to 1v/oct as possible (voltimeter shows 0.97v @ C1, trimmer won’t go any further, so i’m going to assume it’s really 1v), but i’m still getting results where the phatty is consistently like 3+ semitones off key.
i should also mention this off key problem is not related to the phatty itself; i’ve made sure it’s in tune prior to connecting it to the sequencer.
any ideas/answers that might explain this?
I heard once from a knowledgable synth guy that all Moog synths were not exactly 1 volt per octave. I think that this was referring to the old days, not necessarily to the new NC made models.
Mind you, I have NO IDEA about what I am talking about here. I am just regurgitating something that I heard from a guy who should know what he is talking about.
I remember reading somewhere that the Voyager isn’t exactly 1V/Oct (the VX adjusts for this). I’d assume since the Voyager isn’t, the LP probably isn’t either.
The Voyager’s keyboard pitch voltage changes by 0.935 V/Octave according to the manual. I’m almost certain that the LP also isn’t 1 V/Octave but i’m not sure if it’s 0.935 V/Octave (I couldn’t find this info in my LP manual). I’ll find out next week and give an update.
BTW, Happy New Year! :slight_smile:
awesome, thats very helpful, and should at least give me something to test with. Thanks, happy new year indeed! :slight_smile:
i’ll post results as well now that i have a little more direction. :smiley:
ok, so after tuning for an hour or so, scale by scale, i’ve troubleshot the pitch problem.
when you plug the V/Oct control from the mobius into the LP’s CV input (dunno if this happens with other sequencers, please post if you have similar experiences!), the pitch jumps up a semitone. This can royally screw up one’s perspective when not identified right away.
You can get around this with the mobius (dunno if it’s a problem elsewhere, but in case anyone is curious or is having similar problems) by pressing down the B key (octave settings didn’t matter, any B is OK!) on the Little Phatty (this drops it a semitone). This fixes the problem, and the rest is something you’ll just need to calibrate for with your sequencer. The best results actually came from having C1 @ 88.4 mV, which, if we take into account the little pitch thing that the LP does (again, i’m blaming the mobius until further notice, i don’t have any other sequencers to test this pitch glitch with), this probably would equal the same scaling as the Voyager, 93.5 mv/oct.
problem solved! i hoped this may have helped somebody other than myself. :slight_smile:
