Lately my LP started acting wierd. Sometimes the Release on both envelopes jumps to max (usually when changing presets) and I can’t change it unless I turn the pot to 0 and then it unlocks.
I would suspect a bad pot, but this only happens when adjusting the Release, no problem with A, D, S.
Could be an internal midi signal assigned to the env cc’s continually being sent some reason. Have you tried a factory reset? Is your operating system up to date? have you tried a different pot mode? pass though, snap, and what ever the third one is. I believe thats the one I use the most actually.
