Whem using my LP stage as a midi controller I always have to bang on the keys quite hard to higher velocity values. is there a way to adjust the sensitivity of the midi velocity?
This should most likely be set on the slave instrument, not on the Moog itself.
Really? I have the same issues when im just recording midi with the intention of sending it back to the LP… I usually end up increasing the velocity manually on my midi tracks…
I don’t think there are adjustable curve settings in the LP.
thats pretty disappointing if it is true. the velocity curve on the phatty is so low I have to put a midi velocity effect on every track I use it on in ableton.
I suggest you guys request this as a next OS feature ![]()
