LP Stage factory presets on Tribute?
I think this may have been questioned in the past.
Can the LP Stage Factory Presets be downloaded from the Moog website and used on a LP Tribute?
If I remember correctly,the answer is YES,but some patches are specifically designed for the different configuration of the Stage.As a consequence,may not sound so good on the Tribute.
Does my memory serve me well?
Correct!
The only difference in how the patches will sound is that if there is a second modulation destination programmed into the patch, you won’t hear the result on a Tribute. So, all the patches should sound the same with the mod wheel down. :slight_smile:
That was a quick reply!
Went away to make a coffee,came back,there it was!
Thanks Amos!
