I have my MLP setup as my main controller now, but I am suspecting
something is up with the polyphony. It seems it is only 3 notes - is this correct?
I thought it should be able to send out at least 8 notes. Is this something
that is known, but can it be adjusted in software somehow?
Yes, I know it is a mono synth, but If I use it in local off mode and then make it
my controller through Logic, I should be able to bang out a big cluster
of MIDI note chords.
The only limit should be the number of keys on the keyboard (37). I can lay my arm on the keyboard and see (using midi-ox) lots of notes go out and stay on, then see them go off when lifting the arm. Is this what you mean?
I’m using my Phatty as a controller in Logic as well, I can bang out thick jazz chords no problem. It’s curious that you’re only able to output 3 or so.
I don’t use Local Off mode though, I just mute the Phatty when I’m controlling other things with it – but I doubt that would make a difference.
cheers.
