I don’t know why, but i can’t find these menu in Master Mode: MIDI IN:DIN/USB and MIDI OUT:DIN/USB. When i enter midi setup menu i can find only these menu: ALL NOTES OFF, LOCAL CNTRLN: ON, MIDI MERFE: OFF, POLY: OFF. Where are the others menu?
And i don’t why, my lp dosen’t send or receive midi signals any more…i ve tested it on cubase with a midi track on channel 1 and no midi information has received. what has happened? What i can do?
…sorry to say that I had the same problem… I had to remove the In/Out board (easy, and it’s pretty small) and return it to Moog… they replaced it. Easy enough to get it back in.
…cause could be a simple static electricity fry. I had the same symptoms of no menu items. Mine’s been fine ever since.
thanks for reply!
Could you explain exactly what i have to do to open little phatty and take out the IN/OUT board? I am pretty scared to do this because i have no experience with circuitry problems
…yes, tech support gave me the proper instructions. Was not hard at all. I believe it was Ryan at support, if he still works there. You’ll be surprised at how little is inside… most circuitry is attached to the underside of the main panel, so you don’t have to worry about cutting some wire by mistake.
…support can also let you know if there is some kind of software re-set you can do instead; it’s been a while since I had my issue, perhaps there is a work-around in the new OS.
