Hi!!!
I have a problem with my LP SE.
When i record in MIDI track with ProTools M-Powered 7.3.1, after two, three notes, they will enchant.
This happens even when I record a MIDI track after having already developed an AUDIO track.
What can I do? MIDI channels match perfectly and the Local Control is OFF!
I’m not sure how ProTools works, but with Cubase you have to make sure the midi through is off. Otherwise the midi signal goes back from the computer and into the LP again. You get some kind of midi feeback.
What happens if you plug out the midi in cable in the LP?
I also have the same problem as Viplay, with every keyboard of mine (Korg M50, Korg Kontrol49 and Yamaha MO8).
And I have the 2.21 OS, I think…
please help! Sometimes I need another octave!
