For the life of me, I cannot figure out any single way to record the audio signal from the audio out on my LP. (Aside from hooking it up to an amp and connecting a microphone to my audio interface)
I have a Fast Track Pro Audio C400. I have tried connecting the Audio Out in the front, in the back, with every type of cable I know of, via midi and nothing is working and I am about to toss everything out a window. I am able to control the LP via MIDI out on a USB keyboard. I can hear it playing in the headphones. Someone please help! How the hell do you get the god forsaken audio signal out of this incredible synth and directly into my DAW to record it?
THANK YOU TO ANYONE WHO CAN DELIVER FROM MY SELF INFLICTED HELL!!!
I use a Fast Track Pro as well. Audio out from LP into Fast Track audio in. Make sure Fast Track Pro is installed properly on your PC/Mac, and then set your audio driver to “M-Audio ASIO”. Then select your input. There should be a number of selectable channels mirroring the number of channels on your interface. Select the channel that you are running your Phatty into. I use FL studio, and have never used Reason, so I’m sorry that I cannot be more specific.
