I’ve got an LP Tribute & the 104 delay. I already have guitar pedals so any foogers will mainly be for my Phatty to run through. I know little about synthesis but can appreciate what the CP might add, at this point I’m really only looking for some sounds to play with & probably not ready for the level of complexity mating the CP to the Phatty for control voltages, connections everywhere, & what not.
I would simply like to buy another foog to go with my 104. The phaser sounds awesome & I hear the Ringmod is great too. I think mainly interested in the MuRF with its variety & stereo outputs I can run into separate mixer channels & pan left/right for spatial ambience. Is the MuRF more for guitar than synth? What combos do you guys recommend I consider with my 104?
What Foogers exhibit the most distinct spatial separation or sounds the most spacious when using their respective 2nd or right channel outputs?
From the manuals, it seems as though the 103 Phaser will swirl around great while the the 105 MuRF might sound alright as the odd freqs channel to the left & even freqs to the right. How does the MuRF actually sound in this capacity, any good?
I know if I use both the mix & direct outs on my 104 sent to two different channels in my mixer & pan the left & right respectively, I don’t get the ping-pong effect I expected.. & so I don’t see much use in the direct output.
Which units actually pan, ping-pong, or swirl well between the left/right channels?
Were the samples on the MuRF page created with actual right-channel output or are they mixed layers?
The MuRF 105 is great for mono to “stereo.” Here’s a sample of a simple mono drone going through the MuRF. You can hear me adjust the envelopes, mix and rate. http://electro-music.com/forum/viewtopic.php?t=11751
Man, once ya go stereo you just don’t wanna go back do ye? I love swirly ambient whooshing cascades of analog dreaminess. I took delivery of the MuRF over the weekend & can say I’m extremely happy with my choice.
Tks for the nice looong sample MarkM! I wish I could hear more examples of guys twiddlin’ knobs of gear I have or wish to buy.
Are you talking about taking advantage of the 102’s modulators in a way other than directly affecting the signal running through the pedal? That is to say, are the 2 modulators useful in controlling or feeding INTO my LP somehow or do you reference them as they simply add to the versatility of the pedal in addition to the actual ring-mod function?
