Loss of audio mixer volume control in 3.3
I had set master menu (2.2) for the option of quick scrolling through bank presets using the audio input volume control, but since upgrading to O.S. 3.3 this option has now disappeared, and the control parameter now seems to be permanantly fixed. How can I return this control to it’s original setting. Is the only way to do a complete machine reset?
Thanks for your patience!
Pete.
As you will see if you read any further, I missed the obvious!!! :blush:
Hi Pete,
when the ext. audio input switch is off you can scroll through the presets, when the switch is on you can change the ext. audio input volume.
Have fun,
Rudi
Doh!! :open_mouth:
Cheers Rudi.
(See what I mean!!!)
Which is the most logical thing to me.
Everything that can be controlled by the hardware interace is way better then being burried in a menu.
Maybe Moog Music considers to change the labeling of this switch in the future to make it perfect.
Hi Till,
I have just been listening to your 1999 “See You” track on the Wave, very nice indeed! :smiley:
Pete.
