Hello MoogerFooger-Forum,
i recently got the MF-101, and i really like the fatness of the sound, but there are some things i feel not so comfortable with,
so maybe anyone has done this yet ? I’m using the MF-101 for bass guitar, btw.
1.) The AMOUNT-Control is too ‘tame’ for my taste …
Before i switched to the MF-101, i was using a MicroModular as lowpass filter, and the Envelope follower was REALLY sensitive,
which was especially good for tapping parts, because i could control the whole lowpass range just with my fingertip … would changing
the AMOUNT pot help ?
Actually, i’ve turned AMOUNT all the way up, and this is the MINIMUM setting for me … it could have double the effect for me.
The Decay-Time could be much faster, too, but that is secondary … ideal would be some Attack/Decay pots, instead of just the Fast/Smooth switch, but really, it’s secondary …
To achieve what i want, i have to turn the DRIVE up much too far for normal playing (Level LED is Red most of the time when playing normally)
Which leads to my second point …
2.) I feel uncomfortable with the DRIVE before the Bypass … i don’t really like a permanent Booster in my signal, especially because i have to turn it way up to achieve the effect i want … it’d be cool to have the drive after the bypass, and some kind of attenuator afterwards, so the overall level doesn’t change when switching it on …
Ideas anyone ? Are some of the things even possible ?
Thanks, n
