Looking for resistor replacement R17
I broke my werkstatt a while back. Fried resistor r17 by messing with the power source.
I ordered the parts from Mouser.com but they came in way to small so my question was if anyone here has had the same issue,
which part did you order?
I’m kinda new with smd stuff.
A link or part numeber would be so helpfull.
The resistors in the Werkstatt are 0805 size. Sometimes you can fit a 1206 size chip in the same spot.
You could buy some of each.
However, since you seem to be new at this, I’m not sure that trying to do the fix yourself is a good idea. Try contacting Moog and see if they can cover this under warranty.
