My Logic 7 (mac OS 10.4.1) is recording and sending back cutoff data and
all other extended cc data, however - my voyager rme v3 only plays notes and pitch
(and the other non extended midi values).
I have been through the whole manual and I can’t find that hidden switch, in logic or the voyager.
Does anyone know what I need to do? I checked my logic environment, I’ve tried multi and single midi instrument setups without filters - nothing as yet.
The midi light on the voyager is lighting up, when I play only cutoff data for instance, without notes.. so it’s getting it.. just not doing it.
Help!
Richard Kegg.
Brighton, uk.
Check the CC-Number you´ve sent and the CC-Number of the voyager listed for cutoff function in the pdf-File for the OS-Functions.
Make sure in the Local off menue all Functions are on.
it appears to be the same cc number. it should be as i recorded the data with the voyager controls.
all other external keyboards don’t have this problem.
How about other MidiMessages?
Does the Voyager receive Modulation and pithcbend messages?
How about the touchpad messages?
Try to control the cutoff via touchpad. Notice that the CC-Number must be assigned in the Edit menue for each sound.
like i said in the first post, it receives all non - extended cc data, ie: pitch, mod, etc, notes on/off, and it’s an rme not a keyboard version so no touchpad..
i’ll try to assign the t.s. but this isn’t really the point. I want all the panel knobs to record and playback like it says on the tin.
