Little Phatty Stage II Preset Issue
Just Picked up my First MOOG Device WOOT
Little Phatty Stage II ..
Defaulted back to Factory …Currently running 2.20
And The Issue I’m having is ..
When I Set to a Preset and start to play .. It a value will change by itself .. and it will jump out of the preset
amber light .. hit a note or two and its red …
Similarly.. if I was on a preset and adjusted to a new sound ..
and I want to compare sounds jumping back to the original preset sound ..
ill press preset.. Switching back and two notes in sometimes instantly it will jump back to the modified sound
without touching a thing ..
Hope i explained that right
Can anyone help ?
I had a similar issue with my Little Phatty. I found that I needed to make sure the poly out section was set to off. It seems it defaulted to 1 when I upgraded the firmware. After I set it to off, everything started working properly again. If that’s not it, then you may have an intermittent connection on the patch button that is triggering with vibrations.
