I just bought an LP a couple days ago, but since I don’t know very much about synths and audio software I’m hoping someone could help me with the following problem:
I’m searching for a way that you can record audio from your LP (not the sounds from Ableton but from the moog) in a clip slot and that you can see wich notes you played (like when you play MIDI on a sound of Ableton)
Now my Moog is setup like this:
1: Audio interface connected usb on PC
2: Moog connected with a normal Jack cable on the audio channel of the interface
Hey,
I don’t have a lot of experience with Ableton, but when my band and I were in the studio recording with ProTools, I had my Little Phatty connected to the mixer via audio out, and I also had it connected via MIDI straight to the interface. I’m fairly certain if you want to have MIDI notes show up, you need to have it sending MIDI data to the interface.
You need two tracks in Live: one audio track receiving the LP’s audio, and one MIDI track receiving the LP’s MIDI information. Record-enable both tracks and when you record, you will be recording two clips. After you have finished recording, you can route the MIDI clip back out to the LP.
I also have trouble with sending MIDI data to the Little Phatty. I would really love to be able to automate the filter, decay or similar in Ableton and then send it to the Little Phatty and record a new audio track.
Are any of you guys able to do this?
I’ve activated remote and sync in Ableton preferences and chosen the LP as the controller. Then, I’ve added an external instrument to a MIDI-track and then chosen the Little Phatty as the reciever, but it seems that only notes are send to the Little Phatty. So, I can get it to play but how do I then automate the filter cutoff?
Perhaps a thread over in the Ableton forum would be more suitable though ..
Load up Ableton and click on “preferences” and then go to the “MIDI/Sync” tab. Make sure that you can see “Little Phatty SE I/II” in the input and output drop-down boxes.
Then load up a new MIDI Channel in you Session View. Then drag in a new External Instrument from the Ableton instruments list.
The in that “external Instrument”, choose the LP and the MIDI channel, and below that, select the audio channel you want to receive audio from (this will be the channel on your soundcard that the LP is being fed to).
You should be good to go now… Hit record in the Session View and it will record the MIDI notes. Then when you’re happy, add a new audio channel and in Ableton’s I/O choose to receive audio from the channel on your soundcard that the LP is going to.
