little phatty FAQ
they should put up an FAQ section for the LP
I wish someone from Moog “Jared”? would read this forum!
Here’s some questions for the FAQ:
  • Can the Moog LP send Polyphonic MIDI notes?
  • What is the current MIDI Specification?
  • Does the LP have provision for software updates offering arpeggiator or
    other function, such as MIDI control?
  • Can the LP’s knobs be used as MIDI control sources?
  • Is the keyboard velocity sensitive?
    rachel
to be honest i would rather they get it right the first time and not have all the os updates and the problems that come with that.
in 50 years if the OS of the voyager stuffs up then your synth is just a heap of scrap unless you salvage all the parts and make a old school analog synth without memory.
if they keep the digital aspects of the little phatty simple it will add to the life-span of the synth
Btw, how will LP work with external audio signals? Will it be possible to adjust the line input signal, or will it be set at a fixed value (dB)?
Exactly, and where in the synth chain is the audio input inserted… is there a mixer to mix in with the on-board VCO’s, or is post OSC mixer, and right before the Filter/EG’s? Or?
I hope it’s such that I can run another OSC through the audio input jack for Sub-Osc fun and modulation of on-board OSCs!!!
Please confirm, someone, PUH-LEASE.
