Hey Guys!
First I’m from Germany don’t hate me for my bad english^^
I’ve tried the last 3 days to control my little phatty out from fl studio. Used the midi out plugin without sucess… buyed the editor which aollowed me to controll cutoff etc. But when I try to control the lp with pianoroll for recording it nothing hapens…
Also an other problem is that the LP didn’t get connected to my computer all the time… Just sometimes like it had it’s own personality^^ Am I the only one with these Problems?
Midi is correctly seted I’m pretty sure with it! Other Synthesizer I use work. Only the LP make big Problems on midi -.-
OK, trying to understand the problem.
How do you have the Phatty connected, by USB or MIDI cables to a MIDI interface?
If you play the Phatty keys, can you record into FL?
I tried to connect it with both. usb works only if my pc can find the lp. the audio output of the lp is connected to an interface & yes i can record if i play on the lp. only when i try to send midi to the lp nothing hapens
I don’t use FL but if you can record MIDI (not audio!) from the LP into FL, the USB connection is working in one direction.
I’m sure it’s something in your FL MIDI preferences.
Perhaps try retitling this thread with FL in the subject or ask in a FL related forum.
My problem is solved! My LP had a defect. The USB board has been replaced and now everything works as it should
