Hi, just wondering if the little phatty arpegiattor can be manipulated to play as octaves. for example (C octaves up and down) kind of funky style. actually, my little phatty is dead but i wish to know that answer. thanks.
Not sure to understand, but I’ll try my best.
You can set the octave range the arpeggio will range on. Then, if you press only a C, you’ll hear many C’s, depending on that setting plus the pattern.
http://www.youtube.com/watch?v=SPaB5r3IHSY
the bass line can be a example.
thanks !!! ![]()
Yep, saw it.
This is a simple “Fond-oct” up pattern. Several ways to perform it, no problem.
I’m glad that you understand what i want.
can you teach me step by step how to program that arpegiattor onthe little phatty?? it will be greatly appreciated
I don’t have my Phatty at hand, only the manual. One solution should be to set your arpegiattor that way:
CLK DIV: 1/8
OCTAVES: 1
PATTERN: UP
MODE: LOOP.
Other settings do exist, but this one should allow you to play the said arpeggio with only one finger!
thanks you very much my friend, this work for me
THANKS!!!
Cool! ![]()
