Little Phatty and MIDI in pro tools
Hello, new to the forum. Very much enjoying the Little Phatty
I am having a few slight difficulties in protools sending midi back and forth to the little phatty, when I adjust certain parameters, such as the the asdr volume envelope I get sustained notes that I can’t seem to get rid of
I’m sure this is some really simple stupid noob question but any help would be very much apprecciated
Hi, You need to check the midi filter in the midi pull down menu(mac). Also, at the left of the midi track itself, in the edit window, you need to check what other things are being recorded, besides notes and velocity. There is a window that shows midi events, you can see on there what is being recorded. Hope this helps.
yes and thank you!
