little phatty 1.03 error updating to 3.01
Hello
Hope you can help me because i just tried to update the little phatty but noticed to late that it was on os 1.03 as i did the update for 3.01 but that one needed 2 to do it.
I just bought it the day before yesterday and now it only says "check for usb module wich it doesn’t have.
Through the phattyloader i can see it wants to read data.at least it read the v2.0 to v3.01 update and then says checksum error.
Greetings ,
Rob.
Please help…
Hello! I have a little phatty stage edition 1,3 oo. I decided to change the firmware to version 2, the installation process an error occurred! And now, on LP a blank screen, keyboard, knobs and buttons do not respond! With repeated reboots the same thing. blank screen and dead LP. What should I do?
Worth a call to Moog Technical support, ask for Rosser.
You did not mention which Phatty you guys have. If the Tribute, I’m afraid that the 2.0 or anything newer than the early 1.x software will not load up. You’ll need a hardware upgrade in order to expand the memory required for the newer releases.
If you indeed do not have USB, it’s either an original Stage or a Tribute.
Call Moog, they will help you get to the bottom of what is possible with your specific machine.
