librarian question!
so is the librarian the only way to use the moog phatty voices, via midi, thru a daw? does it work similar to the access TI???
the LP only has ONE voice it is NOT multitimbral. You can hook it up to a DAW via midi and/or audio and use it as an analog Moog or as a midi controller for OTHER VSTi’s. The Librarian is not needed for this. All it does is provide a way to store/send sysex banks or edit an existing patch on the Phatty via the Editor program. If you want to record the LP sound in a DAW you have to hook up the audio out to an audio in on your DAW, midi provides NO sound information only note/length/velocity/etc. You will get no sound out of the LP if only midi is used. Choose the midi device you have the LP hooked up to I don’t know what hardware you use.
Again..midi contains NO sound…you MUST hook up the analog OUT to an analog IN on your DAW to record the LP voice.
cheers
LPTE #585
TP? what uhh, do you mean LP???
you said it has only one voice? does that mean that if i hook it up via midi, i can actually use the phattys sounds on my daw? thru midi???
what midi software device would i choose??? sorry if i sound like a complete noob, im a little confused…
One voice…as in, MONOPHONIC. The LP does NOT export it’s sounds through MIDI. Only by running the audio out to analog in on a sound card can you record the LP sounds onto your computer. When used as a MIDI controller, you can send out multiple notes, up to 37 of them, at a time.
thx
