Am having some problems with progamming LFO Rate CC changes in Cubase. Does anyone know what the CC is? When I recorded some data from moog voyager to cubase, it showed on CC35. But no effect is heard when I manually draw how I want the rate to change.
Hi, as Stiiiiiiiive said the manual will have the CC # you need, however I think cubase is HEX or DECIMAL I forget?
its been years since I used cubase but I remember having this problem also.
Download a HEX to DEC conversion table off the net, I think I got an XL doc for free… I think the latest monomachine manual has a hex to dec conversion table in the back of it, I just sold mine so cant dig it up, but you might be able to download the manual off the elektron site.
I think Stiiiiive is a Mono user, he might be able to help
Basically there are two sets of numbers that correspond to midi CC # and cubase uses the opposite to what the manual says.
Here’s what I think, which you may check or some other Moogist will confirm:
LSB = Less significant Byte
MSB = Most Significant Byte
Grosso modo, classic MIDI values are coded on one byte while the Phattys can handle a 2 byte format. The most significatn yte is the one involved by classic MIDI. So my guess is you should use the CC#3.
This 14 bit MIDI stuff (yeah, not exactly 2 bytes…) is described in the manual too. Re-reading it may be useful for you now.
