Probably a simple question but how do I patch my M32 to use lfo modulation from the wheel of my midi kb? Thanks
My version:
- Patch LFO out to Mix2 input.
- Patch assign output to VC Mix Control input.
- Patch VC Mix output to VCO Mod input.
- Set VC Mix knob full CCW.
- Set VCO Mod Source switch to VCO Mod.
- Set VCO Mod Amount knob to about 8 o’clock.
- Set Assign output to MIDI modulation wheel. (Mode 12, MIDI CC 1)
- Adjust LFO rate and play away.
Thanks Wesley I’ll give it a try.
Brill! works great thanks Wesley.
- Set assign output to midi modulation wheel (Mode 12, Midi CC1)
Hi, Would you like to explain how to do that?
I cannot obtain a result with this config.
Thanks in advance
VD
