Level adjusting devices to run Line6 pedals at synth levels?
I have the whole set of Line6 stompboxes and find it annoying that they distort except on low levels from synths and line level devices. Line6 state “If a loop is the only desirable way to connect a Line 6 Modeling pedal, you will need a -22db pad on the front end and a +20db buffer on the output to make up the gain”. Does any one device do a pad down (keeping the impedance high for the stomp box) feed this out to a stomp box then boost the level back up? And in stereo?
I need this!
B
