Friends,
I want to share with you a discovery that I made, well I don’t necessarily claim that its my discovery because im sure that im not the only one that has discovered it.
I have an Etherwave Standard Theremin.
I read that Theremin was working on a way to get 2 pitches simeltaneously with his device, the second pitch coming from the left hand VOlume Antenna.
I don’t think that he ever truly developed it.
My discovery
I was running my theremin through an Electro Harmonix Bass Balls pedal. For those who don’t know its a twin dynamic filter for Bass Guitar. When turned on, especially on the overdrive setting where its mostly used, It truly boost the crap out of the theremins initial signal.
Heres how you find the sound:
WHat you do is you let it warm up as much as its going to and tune it in the traditional way of having your body standing outside of the field of capacitance.
There is a realm of sound hidden in the most extreme border regions just before you will hear the first click of the pitch oscilator. Thats where you want your right hand to be, right in the immediate outskirts of ALMOST activating the pitch Osc. Outside of this there is a silence, but as you approach this area it satarts to make a fuzzy sound.
Granted your goal is to put some headphones on with the volume boosted about as high as you can get it being extremely careful not to activate the oscilator as it will be painful to the ears. You want to boost the signal as much as possible with an amp or something.
Then what you do is you move your hand away from the volume antenna and listen close. You don’t want to activate the pitch oscilator. You shoudl hear a cracking or some feedback in the form of what sounds like a waveshape coming from the volume antenna.
Experiment with this and let me know if it is doing that on your theremin and if its not then what Ill do is I will get out my theremin and Ill do it and Ill give even more precise directions, as this is something that I just pulled from my memory.
This is the sounds that I believe Mr Theremin would have eventually developed, of someone hasn’t already. I think its having your left hand controlling the volume and the pitch of one wave and having your right hand control the pitch.
Let me know what you find out.
