I’m going thru all the presets and ill be playing a sequence or arp, and when I press Latch it just starts repeating the one first note only. Am I doing something wrong?
If it only happens when the 37 is connected via usb/midi then you most likely have some kind of midi loop - eg you have a DAW track that is both monitoring the sub 37 and sending midi to the sub 37 simultaneously, so that the first note is being played into the DAW and the DAW is then sending that note back out to the 37 as a new midi note event.
Other than that you might have something strange going on with your CV MAPPINGS (GLOBAL >> 2.1) - as there is an option to route to ST1 RESET, which resets ARP/SEQ to the first note.
