Probably an easy solution to my problem:
When I create a sequence (say A-B-C-D) and I make it play, I get: A-B-C-D-a little bit of time -A-B-C-D-a little bit of time -A-B-C-D…
Instead, I would like the sequence to play A-B-C-D-A-B-C-D-A-…, what I am missing?
Methodology used:
Bring the ‘Pattern’ knob to the far right position (Rec)
Press once on the ‘Rest’ button
Play the sequence in legato (A, B, C, D)
Bring the ‘Pattern’ knob to the ‘Step’ position
Press on both Rest & Tie
Press A
==> leads me to the aforementioned issue
Thanks,
Louis
cheopsnet:
Methodology used:
Press A
Thanks,
Louis
You’re not missing anything, you are adding!
Just to be clear, you are saying you do NOT want the “little bit of time” in that sequence? So, don’t add the “Rest” at the beginning of it. That’s what’s causing this. Simply turn the pattern knob to “Rec” and play the notes that you want, then switch it back to “Seq” and you can now hit the “On” (Rest) and “Latch” (Tie) buttons and press your “A” note to trigger your sequence.
"He is adding
And subtracting
He’s controlling
And composing
By pressing down a special key
It plays a little melody
(Kraftwerk - Pocket Calculator)
Thanks! Aha that was a simple fix indeed
