Hello
what do you usually do for independent L/R delays? The MF104/Z has only one audio input so do you process each channel individually? If you feed it a stereo signal (or the sum of L/R) and it gets a single delay, is there a way to separate the two channels afterwards?
plug the 104 into the send return loop on a mixer, have two channels on the mixer turn up the send to your hearts content and mantain control over the individual channels, you donβt have to stop at two channels!
or get two for more control over the stereo field with regards to delay.
