L.P.,Voyager and Foogers
Im embarrassed to ask but how do I hook the L.P.,Voyager RME,and foogers together? At the moment Im using the L.P. as the midi controllerfor the RME.Also, can I Mix the RME and L.P. together? Thanks
Run the audio out of the LP into the audio in on the RME for some fun. You’ll need to match up the envelopes for it to be consistent. Sound is a little mushy w/ 5 oscs but cool and massive (similar to what happens when you layer 5 guitar tracks on top of each other!)
From there you could take the mono out from the RME (w/ LP included now) into the foogers in serial. Adjust drive levels to taste, and bypass as necessary.
and…screw w/ CVs to your heart’s content. :slight_smile:
Thank you very much for the reply, I will try it out.
Thank you very much.
