KORG KR-55 with LP
Hi:
I have never used the CV INPUT of my Little Phatty. I have a drum machine KORG KR-55. This has a TRIG OUT +5V-GND. Can I conect My KR-55 to the Little Phatty to sync the rythm with the arpeggio?
i don’t think the LP has an input to control the tempo of the apreggiator. Do you know what the Trig Out is controlled by?
Oh, I see that the LP has a Gate in, so if the Korg Trig Out is sending out a voltage for the tempo, you could connect the two to have a crude arpeggiator (you would have to press which key you wanted to trigger the pitch and the korg would be triggering the start of the envelopes).
Thanks. There is no problem with the voltage because the little phatty accept -5V to + 5V and the KR-55 +5V, is’nt there?
I don’t think so, as long as +5V is the top voltage the Korg can reach.
And Where could I connect in mu Littel Phatty?
