LO guyz!
im new in real analog world and start tweaking my presets in a way i like/…
i really miss any velovity source into the modulation matrix.
but i heard that some preset however have a certain response on the strike a hit my keys (for an example play different dynamics in the preset number 82: Pick Side)
I need to understand how they program this kind of behavior in order to use it in my own futur sonic design…
also i wondering how can you program a tremolo or virato in the LP?
The LP is velocity is routed to the filter cutoff. Under the menu: advanced preset settings scroll down to filter sens cursor over to the value and use the knob to select a value. The higher or lower the value the more the filter cutoff frequency is affected by the velocity. A setting of zero means velocity is off. + values will raise the cutoff and negative lowers the cutoff with more velocity.
Vibrato select pitch as the LFO destination triangle wave as the source, with the mod wheel all the way up adjust the LFO depth and rate to taste. Then use the mod wheel to bring it in as needed.
Tremolo would require an external LFO or the CV out mod bus (if you have the CV outs) routed to the volume CV in. It can be faked in a couple of ways, one is with a low filter cutoff tri LFO to filter cutoff.
