0.9.44 and 1.1.24 are looking very good, from my perpective.
Here’s some rough-edge issues that might need attention some other day, some other release.
Many of these are old, some were raised by others, none are earth shattering.
The Sequence Mod Destination list has these entries:
ARP Pattern
LFO1 Phase
LFO1 DutyCycle
LFO2 Phase
LFO2 DutyCycle
which do not exist, as far as I can tell. -
The Sub 37 manual discusses a sequence pattern rotation. The editor has no notion of that.
The keyboard tracking knobs for the modulators show their values as percentages. Double click to enter a number. The value popup shows a percentage. But entering a percentage, to match the prompt, is wrong. The input is really a big-num - you need to enter 8192 to get 100%. (which I understand - I just don’t like the popup telling me to enter a percent.)
The CV Mapping destinations include LFO Rates, but they’re missing from the other mod destinations - MOD1 MOD2 and seq mod dest.
Hover over the Setup button; get “Click to open the preferences window.”
Hover over SW/FW versions on the Setup page, and get nice popups.
- would be nice if the strings could be copied
- for example, one combined SW/FW string for paste into bug reports
- or an Info button to popup a panel with info to copy: sw/fw/os/date …
- Inconsistent mouse-pointer for MOD Hi Range
- the rule seems to be “on/off” is a pointing finger, otherwise an arrow for multiple choice.
- the MODs Hi Range gets an arrow, while Sync and KB reset get the fickle finger of fate. (left-over from lo-med-hi range?)
- Cross panel drags:
- drag LFO1 KB Track from 0 to 165%, or drag LFO2 KB Track from 0 to 80%
- the value popup jumps to another knob, interrupting KB track adjustment.
- only happens when the drag crosses the upper/lower panel boundary.
- We can confuse the librarian and give the middle column a reddish tint:
- select a preset, drag it to the User folder, then well below it, and drop.
- get a reddish tint in the middle column.
- (because of the unfinished drag and drop)
- clear the tint by dragging a preset slightly out of position.
- the tint does not occur if the drag path is down past the folders and then to the left.
- It knows not to let us put presets directly into the Preset Library directory.
- We can put presets directly into the Presets Library directory:
- click in the blank area below the User folder, to deselect all folders.
- drag a preset over from the Hardware List.
- drop it onto the blank area below the User folder.
- or drag and drop a preset from the OS.
- the presets get placed into the Presets Library directory.
- The Librarian doesn’t remember the last used directory:
- select a folder, double click on a preset to edit it.
- go to another page, then come back.
- no indication of which folder we’re using, although we see the contents of it.
Librarian sorting: when sorting by category, it should sort by names within the category.
Librarian: Should the search field be per-folder?
- select Factory Presets.
- enter “acr” in the search field.
- copy Across the Sky.
- go to a test folder (with some other presets already in it), and paste.
- see only Across the Sky, because the search field is still set.
- Librarian: ‘Save as’ doesn’t take the hint of the current selected folder:
- select a folder
- init preset
- save as
- get the upper level directory, “Presets Library”
- would have preferred that it chose the current folder.
- (well, sometimes it does)
- Librarian: sub-folders can be hidden:
- select Trash Audio
- press return key; the sub-dirs got folded up
- go to other preset folders
- come back
- looks just like an empty folder
- perhaps an icon change to represent folded up folders - a folder outline with plus-sign in it
- The icon.
