Can someone please clarify whether the Moog CP-251 natively S-Trig or V-Trig compliant?
I have looked at the product spec and had a quick search of the forum and haven’t found the answer.
Most of the gate-outs on my equipment are V-Trig (Doepfer Regelwerk etc) and I want to know if I will need to make up a gate to S-Trig cable with 10k resistor and npn transistor?
Why do you need to connect a gate through the cp? The cp has no trigger or gate inputs. The only thing I can think of to use a gate on the cp is either multing a gate, or using the lfo to gate an envelope. EIther way, s-trig is really not relevant, unless you are triggering old moog gear. I have been triggering my model D with the LFO and mp-201 using a 1/4" to s-trig cable with the resistor/npn/zener diode, but only because the minimoog only takes s-trig. I don’t know of any other gear, especially modern gear that takes s-trig.
If you have ever seen old moog gear, it has a plug that looks almost like a lamp plug with 2 prongs except smaller. The circuit is open by default, but when you short it,(both prongs are shorted to each other), it triggers the envelope generator.
How would you convert a short to a voltage? I know there are modules that do it, but can you do it with just a simple circuit like with the s-trig to gate?
