Interfacing the Voyager with MIDI and Modulars
As I have been considering buying a Voyager and eventually, a modular synth, I have been thinking about the value of a MIDI inteface on the Voyager. I suppose that there are those purists out there who see anything that resembles something with a computer chip to be a object of great scorn and disgust. I am not in that group.
I am also not in the group that thinks that all things can be created with a computer program and an audio interface.
So I got to thinking about modules. Modules have gates and CVs right? OK, I am not an expert on this and really, I am just learning but you have basically audio, signal that trigger modules and CVs that control modules in real time.
What I believe could be replaced by digital components are anthing that processes gates liike logic modules. Here is an example from Cynthia:
http://www.cyndustries.com/modules_logicpac.cfm
Now computers are great at logic and timing. Not only do I think these can be replaced but a whole host of sequencers and products like the Flame Clockwork. Even products like the Buchla source of uncertainty. Isn’t it easy to create a program to generate random MIDI notes with pitchbend and then generate MIDI messages? An experienced Reaktor user could probably know this one off in no time.
So what is the difference? Frankly, for gating, I don’t see any difference and a computer can do it better and much cheaper.
Everything that has to do with the audio patch and CVs I would keep in the analogue realm. There are some good reason why computers can’t accuratly emulate these modules.
If I do buy a Voyager, or rather when, I will buy one soon, I intend to bring the digital and analogue worlds together and hopefully show that they blend very nicely as long as that which should be analogue is kept analogue.
Have you investigated MOTU’s Volta yet?
Just a few links for your consideration:
http://www.xfade.com/Gyre/
http://www.xfade.com/Buchla/
Another set of modules to consider the digital world for - LFOs. These are below the audible range right? If they are being used as sub audio modulators then why do you need analogue?
Now here is where MIDI fails. I advocate a more advanced model called Open Sound Control:
http://opensoundcontrol.org/introduction-osc
Open sound control has been used in product like Max/MSP
Jazz Mutant’s Lemur
http://www.cycling74.com/products/lemur
and Native Instruments Reaktlor as well as a number of other programs.
The basic problem with MIDI is that it was designed to make synthesizers of different makes talk to one another. Synth companies were already doing this with there own synths but MIDI formed a universal standard. No one probably expected it to take off the way it did or for that matter, what a computer could do with it. They also did not antipate the type of controllers around today that require a high bandwidth. A stream of MIDI CCs will choke a synth or computer.
I put these ideas out there only to similate discussion. Moog Music is obviously not opposed to MIDI and I undestand that Moog has a certain analogue tradition to uphold but why not join the two worlds that already have been in both the Voyager and MIDI Murf?
My modular has a Q104 MIDI interface. I derive gate, trigger, velocity and pitch from it. My modular is only 12 modules right now and I use it almost exclusively as an adjunct to my Voyager. With the 351 and 251 (Which is like 8 more modules) I get pretty good flexibility and some really cool sounds. The more I use it as is, the more I begin to rethink the 44 space monster I planned.
Aha!
Your rig proves my point exactly. These hybrid systems can work great and provide more flexibility. Great post!
