OK, I knew it would be a mistake but I did it anyway, and now I wish I hadn’t. I’m talking about downloading presets.
I’ve got a sig. edition with OS 2.5 in. I thought I’d try the available downloads on the software link here and it’s gone pear shaped. I’m left with the first seven patches filled, rest is garbage.
I used a free utility from alesis (freeloader) which I use without fail on all my other synths. I enabled sysex on the Voyager, played the sysex files into the Voyager, got the midi LED on, and destroyed my presets.
Are the sysex files on here OS specific? All I desperately want to do now is reload my ‘old’ presets. Is it freeloader or have I dropped a clanger elsewhere?
Come on guys, I only need to know if the sysex banks on this site, are specific to a particular OS or will they work with 2.5?
I’m going to try MidiOx tonight, to see if I get any further with that. Having trawled through previous threads on here, I’m now totally confused over which sound banks will work with which OS. All I want to do is restore my 2.5 with a bank of sounds, do I need a particular sound bank for 2.5?
OK cheers, I think it might be down to this Freeloader application. Will try MidiOX tonight. Anything I need to be aware of with that, I’ve changed the I/O buffers to 512/32, anything else?
I’d rather get some sounds back in before I go up to 3.1
I can download banks into the Voyager with MidiOx (Zonsyx is currently in) but I’ve got no pitch bend? If i go to the ‘Edit’ ‘Pitch Bend’ amount and set it to ‘off’ the presets are at the correct pitch. If I set it to any other value the pitch changes across the keyboard and I’ve still got no pitch bend.
To recap:
all I want to do is restore some decent patches that work fine with OS 2.5.
Can somebody please help with where I can either change what I’ve got or download a new sysex file?
I’ve read that on a couple of other threads. Where is it and does it exist in OS 2.5?
Do i go into the copyright section of the ‘Master menu’? If I do that I get some blurb about Rudi, and the date the software was written, but then what do you do?
