I’m trying to get some feedback on how to make some really good howling wind on the Voyager. I know the oscillators will be off and the noise source will be used.
I have the aftertouch mod on my Voyager so I’m thinking maybe routing the resonance would give a whistling sound? It also needs to raise and lower in volume as the intensity goes up and down. Some solid pointers would be greatly appreciated.
So did I pretty much get it with my idea of how to make wind sounds or is it some kind of ancient Chinese secret? I won’t have free time to get on the Voyager until Saturday so I was hoping for some helpful tips before then.
Yep, that’s how you get wind. You have to be careful with the settings however, because surf sounds are also made this way.
A couple of ideas:
You could place a MuRF of BMuRF in the Voyager’s Mix/Out loop to alter the character of the noise. With proper settings, the MuRF/BMuRF could add a nice bit of randomness to the sound (upping the authenticity factor), or if used statically, could shape the noise into something more suitable for a real wind sound.
The Ring Modulator might be able to add something interesting here, so I’d suggest trying it.
you can also try to run noise through a phaser, it will give a nice animation to it. Modulate the sweep with a very slow (random?) LFO… some panning can help too.
Yup, I’ve used a Mu-Tron Bi-Phase for wind. Used lightly and tastefully, it will add additional realistic variation. This is a top-notch phaser though, where you can run separate stereo phase channels modified by independent LFOs, rates, waveforms, depths and feedbacks. You can also chain the channels.
I hadn’t thought of using a phaser either. Thank you very much for those tips as well. I’m from New Orleans and the song is about the city and the effects of the storm so I have an aggressive wave patch I made, but the wind is necessary. These tips will help me make very good wind.
Since I’m here and Saturday is still 2 days away, do any of you know how to make a good rain sound? Seems liek it would be just the noise generator itself and maybe the phaser or Murf trick?
How about thunder? That one I think is probably a hard one to pull off.
Lengai, theres a thunder patch in the files section of the V’ger Yahoogroup, in the folder, “LWG patch”.
Its a template from one of my banks and should point you in the right direction.
One last thing: If you load the patch in your V’ger with a pedal in the mod
bus, I don’t know if the pedal bus amt will have it’s default setting for the patch, or the pedal will have added to or subtracted from the correct setting
(which is 044 midi) based on its travel position.
I’m not using the pedal, so you may want to try the patch first without the
device patched to the mod bus.
Thanks for the advice. I just uploaded OS 3.3 over the weekend. I actually spent most of my time setting up a compressor for sidechain so I was in cable hell and did get the thunder patch ready to go, but I will put it in tonight.
So I downloaded the thunder patch and got it ready for a sysex dump to the Voyager. I set the Voyager to “Receive Presets” with sysex enabled and no dice. Does this mean I have to have the Editor program on my computer to load a single preset onto the Voyager?
If so I’m in trouble because I run Mac OS 9.2, not OS X. Is there any way to load a single preset onto the Voyager (OS 3.3) without the Editor software? Maybe a whole bank of the same preset and then load the AE ones back in when I’m done?
If not, would you happen to have the panel settings for the thunder patch so I can dial it in myself and save it?
I’m sure it’s easier than this. I don’t quite know the full details, but remember hearing something about loading the desired patch into the compare buffer (receive single preset?) and this might have to with the way the patch is saved by the contributor. If the patch was not saved this way, you might have to go looking through your all your loaded patches to find in which place it was originally saved.
If it’s in the compare buffer you should hear it straight away and be able to save it where you want.
I was reading about the compare buffer in the notes last night (OS 3.1 or 3.2 I believe) and was thinking that might do the trick, but I was confused so I didn’t try it.
I sent the patch so maybe it is on the Voyager somewhere? Now I’m happy to only have 128 presets on 1 bank
I’ll look for it and hopefully it’s there.
Can anyone that uses the compare buffer to laod single patches please explain it in a way that a simpleton like myself would understand?
AFAIK, the only way a patch is loaded into the Voyager’s Patch buffer (AKA Edit buffer) is if it was originally saved using the ‘SEND PANEL SOUND’ selection (3.1 in the Master Menu). Back when I ran the SquareWave site, this was the recommended method for saving a patch that would later be uploaded to the Voyager patch database. This method insured that when the patch was loaded it would go into the Voyager’s patch buffer instead of overwriting an existing patch, saving users the aggravation of having to hunt for the new patch.
It sounds like LWG’s patch wasn’t saved using ‘SEND PANEL SOUND’ feature. Since you’ve already loaded it, however, I’m betting that the patch somewhere in the sound bank - you’ll just have to find it (do you know what it’s called?).
A while back, Till Kopper wrote a little program that converts a defined-location Voyager SysEx file to one that will load into the patch buffer. For future reference, you can find it here:
Lengai, although I have the SoundTower editor, when I post patches in the public domain, I post them as sysex, as I assume that many Vger users
don’t necessarily use the editor.
The application I use is Midi-Ox, on PC. This may be a possible source of the snag, as I used the “Panel Send” command when saving the patch to
sysex, so it should be in the edit buffer.
What Mac app are you using to receive sysex? Do you have any problems
loading single patches you’ve saved from that application?
LWG is correct - you don’t need the Editor for sysex patches. A reliable Mac app for sending/receiving sysex files in OS9 is the Bulk Sysex Utility. If you don’t already have it, you can get it here:
my little tool is working for Mac OS X and Win XP.
I have no Vista here to check it on this OS.
But it does not run on Mac OS 9.
This is only because I did not compile it for this older OS.
I may do so. But I am unable to test it on OS 9, because I have no Mac with this OS here at all. But I am not depending on special OS features at all. So it should be possible to do.
I use Sysex Loader (or a name really close to that). The thunder patch is the first one I’ve ever tried to load in so that’s why I’m confusing myself. I was in my home studio for 6 hours yesterday, but I was so focused on what I was doing in Cubase that I didn’t even think to check the Voyager
I will tonight and let you guys know. I appreciate all of the help with this. I’m sure once I do it right the first time I’ll have it down.
